Discussion topic: Record Series With 2 consecutive episodes
This message was authored by: LBJ501
If there is a series with 2 consecutive episodes, Record Series doesn't work even if u record both episodes.
Re: Record Series With 2 consecutive episodes
hi @LBJ501
Is it definitely not working for you an a specific programme ?
In case you don;t know the link only shows for the next recording & will only show on the second recording when the 1st one starts to record
I have several links where 2 episodes are often consective and these work.
Of course, it is always possible that the link for a specific programme series is incorrect - if this is the case best to email Viewer Relations : viewerR@Sky.uk
Avatar for LBJ501
This is  a software bug and fails on any series that for example, have Episode 1 at 8pm and epsiode 2 at 9pm, it even fails if you put both episodes on series record, the 2nd episode will not record for Episode 4 for example.
it is more likely to be a specific Link problem for the series you are trying to watch
As I say I have several sereies where episodes are consecutive and record on link OK
Edit : BTW Channel 5 is  notorious for not recording both parts of Films split by News
Avatar for LBJ501
No it doesn't work for any series on any channel. This is the same bug that has been there for years also on SKY HD
