Discussion topic: Record Series With 2 consecutive episodes
Message posted on 09 Dec 2024 11:20 AM
If there is a series with 2 consecutive episodes, Record Series doesn't work even if u record both episodes.
Message posted on 09 Dec 2024 11:34 AM
Re: Record Series With 2 consecutive episodes
hi @LBJ501
Is it definitely not working for you an a specific programme ?
In case you don;t know the link only shows for the next recording & will only show on the second recording when the 1st one starts to record
I have several links where 2 episodes are often consective and these work.
Of course, it is always possible that the link for a specific programme series is incorrect - if this is the case best to email Viewer Relations : [email protected]
Message posted on 09 Dec 2024 12:52 PM
This is a software bug and fails on any series that for example, have Episode 1 at 8pm and epsiode 2 at 9pm, it even fails if you put both episodes on series record, the 2nd episode will not record for Episode 4 for example.
Message posted on 09 Dec 2024 12:55 PM - last edited: 09 Dec 2024 01:00 PM
it is more likely to be a specific Link problem for the series you are trying to watch
As I say I have several sereies where episodes are consecutive and record on link OK
Edit : BTW Channel 5 is notorious for not recording both parts of Films split by News
Message posted on 11 Dec 2024 11:19 AM
No it doesn't work for any series on any channel. This is the same bug that has been there for years also on SKY HD
