Discussion topic: Equipment not working
This message was authored by: Sammorri
I have recently had a max hub fitted And all my main equipment is fine I have just received a mini sky Q box had that just over a week. Everything was fine then after the sky hub it won't connect to my other box. When I turned the box on it asked if the box had been signed on before and I said no. Then it said the box had to reset and then when it says to push the home key to continue nothing happens and my remotes not working. I don't know what to do can you help.
Re: Equipment not working
Hi @Sammorri
Reboot the mini as above.
If the mini doesn't come on with the remote after the reboot press the Amber led on the front of the box as this is also the standby button.
If you had to press the standby button on the Q box to bring it on then,
With the mini box on with green led try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
