Discussion topic: Reconnecting moved sky mini box to sky q
This message was authored by: Mezebede
I have moved sky mini box to a new TV, the Sky Q main box is connected to satellite and internet, mini box is connected to internet but get stuck on step 2 after I press correct button which then flashes on  sky Q. How do I overcome this ?
Re: Reconnecting moved sky mini box to sky q
@Mezebede so its asking you to press the WPS button on you main Q box and you are doing this and nothing happens ? D you get any messages ?
LG 49SJ 810 V UHD TV, Google Pixel 10 Pro XL mobile
Avatar for Mezebede
It starts the process on the minio box with flashing light on Q box and orange flashing on mini box but gets stuck on step 2 and says it can't connect. Once it got to step 4 and started to upload the TV schedule but stopped.
@Mezebede is the TV you moved the mini box to closer or further away from the main box than what the mini was before you moved it and who is your broadband with ?
Avatar for Mezebede
The new TV is further away from main Q box but only about 20m , broadband is BT and fast.
This message was authored by: Invisiblename
The broadband is irrelevant as the mini connects to the Sky Q box directly via Sky's own WiFi mesh.
I am just another Sky customer!
That's probably too far from the main Q box.
Sky may provide extenders if you call them.
