3
This discussion topic has been answered Discussion topic: Battery Symbol
This message was authored by: Rugbyreddragon
Battery Symbol
I have a battery symbol appeared on the screen. Does this refer to the remote control needing new batteries?
This message was authored by: Invisiblename Answer
Re: Battery Symbol
@GD1 wrote:
Short answer, Yes
Long answer, yes it does 😁
I am just another Sky customer!
Re: Battery Symbol
Short answer, Yes
Re: Battery Symbol
Short answer, Yes
This message was authored by: AnytimePlus+On+VM
Re: Battery Symbol
In theory yes.
It can come up very early though.
Ours has been showing the symbol since last June (2024) and yet we have no issues with the remote.  It works perfectly when pressed - no issues at all.
Of course we could just swap the bateries, but it seems a waste when they don't need swapping and seeing that the icon only appears on the home screen and doesn't block anything we haven't changed them.
