Discussion topic: Re: Some Sky HD Channels not appearing (blue screen)
Message posted on 01 Dec 2023 10:36 AM
Hi. I had a problem with my SkyQ main box. I rang SKY and after going through several attempts to get it working, the advisor told me there was a fault with the box, and was sending out a new to me. It arrived, and I used the accompanying booklet to set it up.
But a whole host of channels have a blue screen and a message to say my satalite signal was not good. I checked all my settings and it told me my satalite signal was strong.
Can anyone point me in the right direction to get this resolved, please.
Message posted on 01 Dec 2023 10:40 AM
I've moved your post to its own thread as you mention Sky Q but added to a thread about Sky+HD boxes.
”No signal” tends to be a message from your TV (in which case check the cables going to the TV). A “no satellite signal” message relates to your Sky box.
If it displays no satellite signal take a look at the troubleshooting here
It may then give you the opportunity to arrange an engineer to check the alignment of your dish. If you’re on a communal dish system in the UK you’ll have to contact your landlord or building management company rather than Sky.
