Discussion topic: No connection
This message was authored by: BECKY3131
No connection
My TV won't connect
Re: No connection
Going to need a bit more detail. You mean it has no signal from the Q? Sky box got a green light? Does that switch between amber and green if you press the power button on the remote?
Have you tried power cycling the Q box?
