8
This discussion topic has been answered Discussion topic: Re: My screen is saying does not support HDCP
This message was authored by: JH17
I have the following error message:-
'This screen does not support HDCP. Try reconnecting your HDMI cable, or use a different screeen'
This is stopping me from watching Sky TV via one of my sky q mini boxes.
I have rebooted the mini box, unplugged the Sky branded HDMI cable, waited 5 minutes, reset the box and I still get the same message. I have done this on several occasions.
This message was authored by: Mjginwales Answer
Try unplugging the tv as well as  sky
and leave for a good few minutes
justvincaenita static on the circuit boards and hdmi etc
When you say several occasions, do you mean it's happened before or that you've tried unplugging and reconnecting it more than once and it has no effect?
It's not static that causes circuits to stay live for a while after the power is shut off, it's capacitors which are designed to hold charge and smooth out current delivery in circuits. They take a while to discharge.
Thanks for the clarification
This message was authored by: ScottyWalker
Tryed so many times & doesn't work. Think box is done.
Tried another cable?
This message was authored by: Gregcov2134
This is happening every time we turn ours on. I've also noticed that when we do, the skybox is really hot. Which it should not be as it is put into standby when the TV is switched off. I'm getting annoyed now.
This message was authored by: Angel32
We have but no joy
