Discussion topic: Re: Loss of channel 512 GB news
Message posted on 10 Nov 2023 11:55 AM
I have the same issue all 3 channels. I have switched box on and off few times. Any other ideas?
Message posted on 10 Nov 2023 11:58 AM
@Milly2023
Sky no longer deploy an engineer for Sky+ / Sky+HD issues. If your issue needs an engineer they will advise you of this and recommend you change your subscription to Sky Q, Sky Glass or Stream. If it’s a dish issue you will need to contact a local independent satellite engineer to investigate at your own expense. The exception to this is if you already have Sky Protect cover through Domestic and General Insurance whereby you can still contact D&G and request attendance.
Message posted on 10 Nov 2023 11:59 AM
Forgot to add i am on Sky Q
Message posted on 10 Nov 2023 12:02 PM
That would have helped 😂 I've moved your issue to the Sky Q board.
If it displays no satellite signal take a look at the troubleshooting here
It may then give you the opportunity to arrange an engineer to check the alignment of your dish. If you’re on a communal dish system in the UK you’ll have to contact your landlord or building management company rather than Sky.
Message posted on 10 Nov 2023 01:25 PM
I'd say that not being able to get GB News is a bonus!
Message posted on 13 Nov 2023 07:08 PM
Lost GBNEWS CHANNEL
For about a week now I can't get GBNEWS on SKY.....is anyone else getting this problem. I'm in Somerset
Message posted on 13 Nov 2023 07:15 PM - last edited: 13 Nov 2023 07:20 PM
Re: Lost GBNEWS CHANNEL
You post has been moved into a thread on this. I believe the transponder for this channel changed recently. Have you tried rebooting your box?
edit- see this thread on the Sky+ board as well
https://helpforum.sky.com/t5/Sky/Loss-of-channel-512-GB-news/m-p/4474741#M144234
Message posted on 13 Nov 2023 08:14 PM - last edited: 13 Nov 2023 08:16 PM
This has been reported to GB News, as has been discussed in this thread.
For all it may achieve. Sounds like a poor decision for their main UK audience.
Message posted on 13 Nov 2023 08:51 PM
Thank you Daniel, I took your advice but unfortunately it didn't work. It did however lead me to a link which has enabled me to book an engineer visit 🤞
