29 Nov 2023 02:24 PM
Posted by a Superuser, not a Sky employee. Find out moreYes, you're right delivery to the Sky Q app is via your broadband connection. I can't find any other recent posts reporting the same problem, so it may be a wifi issue. You could give Sky a call?
I've moved your post to the Sky Go & apps forum where others with a similar problem are likely to be aware of it.
29 Nov 2023 11:13 AM
29 Nov 2023 01:27 PM
Posted by a Superuser, not a Sky employee. Find out moreHow are you watching? Are you sure this isn't a problem with your dish setup?
29 Nov 2023 01:28 PM
Posted by a Superuser, not a Sky employee. Find out moreI experience no issues with TNT Sports do as @Mark39 suggests it sounds like an issue with your specific setup?
Which Sky services are you subscribing to (Plus, Q, Glass, Stream)?
29 Nov 2023 01:38 PM
Mark39 I am using Sky q apps menu to access Discovery plus. My understanding is that this content as with all other apps(Netflix Prime etc) is delivered via Internet not Sat dish? So I think the app is flawed, never a problem on BT Sport
29 Nov 2023 02:30 PM - last edited: 29 Nov 2023 02:31 PM
Apologies @Canary1953 my reply to your above post has become out of sequence, and appears as the first post in this thread: https://helpforum.sky.com/t5/Sky-Go-Apps/Re-Discovery-plus/m-p/4494075#M130502
29 Nov 2023 03:15 PM
Hi Mark, in response i do not have any wifi issues or any issues at all with any other apps on the menu only Discovery? It must be a Discovery app issue and Sky need to investigate. As far as no other complaints on champions league nights Twitter (X) is full of similar complaints
