Discussion topic: Random recordings
Message posted on 25 Aug 2024 05:29 PM
Random recordings
Hi. Inhave switched from a previous package due to it being stupidly expensive. To the lowest package which is basically Freeview. For some very weird reason my Sky Q box is recording series I would never watch on Channels I have never watched. Two series this morning, not there yesterday that were recorded. I selected the remove series link and deleted said programme. This has happened three times now, and to be honest I rarely watch TV. Mostly the Apps.
I thought it was my imagination, but sure enough there were more recorded series. Why is this happening and how can I stop this
Message posted on 25 Aug 2024 05:34 PM
Re: Random recordings
Hi @Babypink2807 You need to review all of your scheduled programmes and tidy up anything you haven't set.
Message posted on 25 Aug 2024 05:41 PM
There is nothing there to tidy up. These are on random channels I have never ever watched.
Message posted on 25 Aug 2024 05:46 PM
Try a Reset Settings in the Q box hidden menu. It may help
Message posted on 07 Apr 2025 07:56 AM
This doesn't work for me!! Has the feature been removed?
