Discussion topic: Random recordings on Sky Q box
This message was authored by: NewtonUnthank
I have recently been upgraded to Sky Q.
Every time I look in "Recordings" I find programmes I did not record. I have not even used the recording facility yet and doubt that I ever will.
Is there any way to deactivate recording?
Re: Random recordings on Sky Q box
Hi @NewtonUnthank
I suggest you have inadvertently selected a series link recording.
Anything that is set to record will appear in the Recordings most recent - Scheduled - section
Check this on your Q box as it should be completely empty.
@NewtonUnthank
Not sure why you would subscribe to Sky Q to never record anything… You can't remove the recording option. Go into Recordings - Scheduled and delete any programmes in there already set to record.
@NewtonUnthank another possibility for unwanted recordings is landing on a non bbc channel that has watch from the start and inadvertantly pressing the select button which will download the programme to your recordings
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for NewtonUnthank
@Daniel0210
I didn't choose to subscribe to Sky Q, I was upgraded to it when I renewed our contract. I wasn't aware that it was possible to renew without being "upgraded" to Sky Q - the Sky agent I spoke to certainly didn't offer me any other option, unfortunately.
This message was authored by: twilight+princess
It sounds like you'd be better with Sky Stream which as it says streams Sky tv over the internet rather than Satellite.
Virginia.
I don’t work for Sky.
If I have helped then please leave a like.
