Discussion topic: Random channels missing on tv guide.
Message posted on 04 Oct 2023 07:33 PM
Does anyone have any ideas to why this keeps happening? every week I need to reset my sky box which fixes it for a few days, then later again we have different channels not showing a programme guide.
I can't record a lot of programmes because of this.
Message posted on 04 Oct 2023 07:37 PM
Re: Random channels missing on tv guide.
Assume that you are putting your Q box into standby when not in use (and not switching it off at the mains).
You could try a Reset Settings in the Q box hidden menu. It may help.
Message posted on 16 Oct 2023 07:01 AM
I think it's because we turned of eco mode which is a bit odd, I've never known of this with older boxes in the past.
It's been fine so far since enabling it.
Message posted on 20 Jan 2024 06:51 PM
I've tried everything but most of my channels are still missing it has been like this for weeks now
Message posted on 20 Jan 2024 06:55 PM - last edited: 20 Jan 2024 06:56 PM
edited wrong answer given
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 20 Jan 2024 07:13 PM
@Ali3773 Ever since I changed my standby mode to eco it hasen't happened once since creating this topic.
I had the issue for months.
Message posted on 20 Jan 2024 07:16 PM
It's entire channels you're missing right? I just realised, that is something different, might require more help here, I hope you find a fix.
Message posted on 20 Jan 2024 08:08 PM
I switched the eco off back last year as my box was turning off upstairs in the night I watch tele all through the night I would have to come downstairs to switch it back on so I would be able to watch the box upstairs cant sky fix this problem
Message posted on 20 Jan 2024 08:10 PM
When I emailed sky their reply was for me to use the guide on my Fone but that's not good enough I will be ringing them mon morn I pay for a service and expect to receive it
Message posted on 21 Jan 2024 10:32 AM - last edited: 21 Jan 2024 10:33 AM
I currently don't have any EPG listings for Channel 4 and Channel 5 from 6am next Saturday. Channel 4 is 'waiting for tv schedule' and channel 5 has 'this is channel 5' across their listings. Every other channel is fine. I've had this happen before with channel 4 and in our case it usually self resolves but it's odd that it's only affecting these two channels currently. Rebooting doesn't resolve it. And I have the main box and two minis set to 'eco'
