Discussion topic: Can't connect to my routers 5ghz channel
Message posted on 27 Jun 2023 07:50 PM
My Internet provider has two channels on the router, 2.4 and 5 ghz. Originally Sky Q was connected to the 2.4 channel. The 5 ghz channel has a different ID to the 2.4 but it doesn't show up in the WiFi list.
Is there anyway to connect the 5 ghz channel without having to contact the infuriating sky "help" ?
Message posted on 27 Jun 2023 07:53 PM - last edited: 27 Jun 2023 07:53 PM
Re: Can't connect to my routers 5ghz channel
Unfortunately not - SKY Q will only use the 2.4GHz band with 3rd party providers
Message posted on 27 Jun 2023 08:30 PM
Thank you for the timely response. Strange though as Zen technical (Internet provider) said it was possible but Sky needed to change a setting in the box.
Message posted on 27 Jun 2023 08:37 PM
If you connect a Sky Q booster by Ethernet to your router then you can use WPS on your Q Box to connect to the 5 Ghz band of the booster
Message posted on 21 Jan 2024 09:43 AM
I have the same problem but I have sky broadband! I split the channels to 5 and 2.4ghz so I can connect outside cameras, now my Q box only finds 2.4ghz and the mini boxes freeze constantly.
How do I fix this?
