4
This discussion topic has been answered Discussion topic: Qbox not working
This message was authored by: Markles
Qbox not working
  • Skyq box keeps freezing fan kicks in, then cannot turn it off or on. Switch it off for 15 minutes, turn it back on again, and will freeze again a few days later thus is now constant
This message was authored by: callofduty Answer
Re: Qbox not working
Had an identical issue. Once I demonstrated I'd been through basic diagnostics they swapped the box immediately. 2 days in with new box all good so far. The old one wouldn't last 24hrs without freezing.
Don't forget to make a note of your recordings if you swap the box.
This message was authored by: Mr+Flibbles+86
Avatar for Markles
@callofduty .
Freezing wasn't quite as bad as yours but was getting there. They are now replacing the box.
Thanks for the tip
@Markles
If it's a doorstep swap don't forget to remove your viewing card from the faulty box before DPD take it away.
Answered - Go to Answer
