Discussion topic: Error code MR001
This message was authored by: Jules41
Error code MR001
How do we reconnect
Re: Error code MR001
@Jules41 wrote:
How do we reconnect
Hi @Jules41
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
This message was authored by: Clivefran
If you have tried everything else including Sky who just wanted to send another box. Try the following.
1. Reset your remote by pressing 7 and 9
2. follow instructions to connect to the main box and internet
3. if the connection is poor even though in settings it says it's connected to main sky box and internet, go to your main box
4. go into setting and network connection. Reset the network even if it says it's connected and working. Confirm a reset.
5. reconnect and you should find the mini box connects properly this time.
good luck everyone on this annoying error
