Discussion topic: Q sky box remote
Message posted on 22 Mar 2024 10:21 AM
Q sky box remote
Hi my remote is not working and my sky q box is not working
Message posted on 22 Mar 2024 10:23 AM - last edited: 22 Mar 2024 10:23 AM
Re: Q sky box remote
Perhaps give us some details first but ultimately, after checking the basics, ie; fresh batteries, re-pairing etc if your Sky Q remote is definitely broken/faulty, if you follow this link it should allow you to do some more troubleshooting and then it’ll send you to a form to request a replacement (apparently this is not available to customers in the ROI).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
It may be quicker to purchase a new remote from a retailer or larger supermarket. If you do that as well as the above you’ll have a spare.
Message posted on 22 Mar 2024 10:27 AM
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Message posted on 22 Mar 2024 10:28 AM
This is a new remote my old remote was broken and I throw it away and yesterday they send me another one and they took my q box like an exchange for the remote I throw it out and they said I need another q box and they provide another q box and new remote but is not working I think the remote because have battery but is not flashing red light on it when I press a button and q box is just showing red light and blue light in the middle button Q
Message posted on 22 Mar 2024 10:29 AM
Yes I have press all buttons
Message posted on 22 Mar 2024 10:31 AM
I have pressed all the numbers 1/3 7/9 is flashing the red light on remote and rahat is
Message posted on 22 Mar 2024 10:32 AM
the red led on remote will only flash when you press the Question mark button (?) or the Microphone button, It does not flash for every button.
Message posted on 22 Mar 2024 10:33 AM
Message posted on 22 Mar 2024 10:34 AM
Message posted on 22 Mar 2024 10:37 AM
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Don’t forget to keep your viewing card from the failed box if you order a replacement. Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box.
Message posted on 22 Mar 2024 10:39 AM
How should I know this to guess? No body tell I don't know how to fix it
Message posted on 22 Mar 2024 10:47 AM
Hello can anybody help I unplugged all cable I have put it back is not doing nothing still the same as in the picture I sent remote not working and button with red flashing is not working when I press no button working
