Discussion topic: Q ox usage problem
This message was authored by: Controling
Q ox usage problem
Occasionally when I select the left hand side menu with the intention of finding another item to watch the menu scrolls down to the bottom without giving me the option to select the menu item that I want.
Re: Q ox usage problem
Hi @Controling   It sounds like a problem with your remote like a stuck key. Also remember the remote is using Bluetooth so is there anything near using Bluetooth like a mobile phone.
Avatar for Controling
Level 2 icon
Thank you for your response.  Unfortunately I have eliminated both possible causes that you have suggested so I am still at a loss as to what causes the problem.  Another peculiarity that has recently occurred is the occasional appearance of a small window showing another channel at the foot of the picture being watched.  That small picture disappears after a few seconds but it is annoying.
Hi @Controling
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Level 2 icon
Eureka your suggested remedy has worked so far.  Thank you.
Level 2 icon
My eurica moment was premature as the problem has reoccurred.  Any more remedial suggestions would be welcome or should I pay for Domestic & General  service?
Spoiler
This message was authored by: SlenderRobert
Spoiler
Do NOT pay for Domestic & General insurance. All Sky Q equipment (including the remote) is loaned to you by Sky for the duration of your contract. If there is anything wrong with that equipment then Sky will replace it free of charge. Just give Sky a call.
Hi @Controling
This message was authored by: bob1234
@ControlingThe only advantage of using D&G is to get accident and theft cover also possibly a faster response time than Sky, apart from that no difference I believe they are even the same "engineers"
Level 2 icon
Am awaiting a visit from Sky engineer that should resolve the problem one way or another.
