Discussion topic: Q mini boxes.
This message was authored by: Penn
Q mini boxes.
Hi
i have 2 Q mini boxes but can only watch 1 at a time. Can not have the 2 on at the same time why?
Thankyou
Re: Q mini boxes.
@Penn
You can have a maximum of 4 mini boxes loaned to you by Sky. You can watch Sky content on two minis and the main box at the same time. You may be able to use a third mini box if the first one in use is being used for a streaming app ie: Netflix or DIsney+.
Be aware the original 1TB (non-UHD) Sky Q box only allows one mini to be in use. To check if you have the non UHD 1TB box check in:-
If it shows as 32Cxxx then you have a non UHD 1TB that only supports 1 active mini box.
All 2TBs and the UHD/HDR 1TB permit two mini boxes. Each mini box which is loaned to you may be subject to a one off upfront charge but you only need one Sky Q monthly Multiscreen subscription.
Avatar for Penn
Re: Q mini boxes.
Thank you I will give them a call.
Re: Q mini boxes.
@Penn
Presumably then you have an original 1TB (non-UHD) Sky Q box?
