2
This discussion topic has been answered Discussion topic: I don’t have a network connection
This message was authored by: Debbie114
I don't have a network connection
Re: I don’t have a network connection
Is this on your Q box @Debbie114 ?
Avatar for Debbie114
Thank you, I've sorted it now and we seem to be working ok. This was helpful and I have sky BB, could be the weather up here. Its -10 and freezing. Thank you for your help
Debbie
