Discussion topic: Q box
Message posted on 31 Aug 2024 08:45 PM
Q box
Tv wont connect to sky Q box but will connect to mini box, bought new hdmi leads but still wont connect through Qbox..
Message posted on 31 Aug 2024 08:47 PM
Re: Q box
hi @Al37
Have you tried rebooting your Q box?
Message posted on 01 Sep 2024 04:48 AM
Re: Q box
What do you mean by "won't connect"? What do you get on-screen? Are you testing it in the same hdmi input port? Are both boxes set to the same output resolution?
Message posted on 01 Sep 2024 06:28 AM
Re: Q box
So telly works perfect through mini box but soon as connect to sky box just a blank screen, tested all 3 ports same blank screen,can stream Netflix,Disney over wi-fi and free LG channels.
This all started when telly just randomly started flicking on off on off with lots of wavey lines running through screen,got sky to send new Q box but same fault, when I say tv on off I mean screen going from displaying program to blank screen like a strobe light
Message posted on 01 Sep 2024 07:44 AM
Re: Q box
Try this
With the Q box on
Press Home
press 1 0 8 0
Press Home
Message posted on 01 Sep 2024 10:07 AM
Re: Q box
Tried rebooting,no joy just a blank screen,Tried the home 1080 home no joy,just a blank screen, it seems as if the signal coming out the Q box is somehow different to mini box and my telly just won't respond to it,I'm at my wits end,both boxes work on an older Panasonic telly, I've made sure output resolution are the same on tv an both boxes,really don't want to buy new telly and find it's still doing it
Message posted on 03 Sep 2024 02:16 AM
Re: Q box
If both boxes are set to 1080i there should be no difference in the signal. Same cable. Very very strange. I'll escalate this one in case thr Sky online team can diagnose. Watch out for a chat bubble.
Message posted on 03 Sep 2024 09:59 AM
Re: Q box
Thanks for escalating. We've sent an invite to @Al37.
Tom
