Discussion topic: Q box
Message posted on 03 Sep 2024 09:02 AM
Q box
Hi, I'm having trouble with my skybox it is saying connected to the Internet but when I go onto the app it is saying not connected to the Internet on settings. It is showing it is connected.
Message posted on 03 Sep 2024 09:49 AM
Re: Q box
Hi @Birds
