Discussion topic: Q box won't accept WiFi password
Message posted on 15 Aug 2024 08:55 AM
I have a BT router
Message posted on 15 Aug 2024 09:12 AM
Re: Q box won't accept WiFi password
2.4GHz enabled and 5GHz steering turned off?
If your router has smart setup, turn it off.
Message posted on 15 Aug 2024 09:35 AM
I have no idea what this means
Message posted on 15 Aug 2024 09:46 AM
Q will only connect to a non-Sky ISP on the 2.4GHz band.
If you router doesn't have this enabled (or it steers to 5GHz or smart setup is enabled) then Q won't connect.
If you don't know how to configure your router then you'll have to seek help from BT (or their forum).
