Discussion topic: Sky box won’t turn on, blue light slowly flashing
Message posted on 15 Mar 2024 10:05 AM
Sky box won't connect blue light slowly flashing
Message posted on 15 Mar 2024 10:37 AM
Re: Sky box won’t turn on, blue light slowly flashing
Hi @Wilkieimi
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Ordering a new Q box usually means a doorstep swap.
Don’t forget to keep your viewing card from the failed box if you order a replacement. Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
