Discussion topic: Q box not receiving satellite signal for TNT or GB News
Message posted on 13 May 2025 08:59 PM
We have called out Sky Protect Domestic and General engineer and he said the Q box is not receiving the satellite signal so we need to contact Sky to get the box replaced. Unable to speak to anyone at Sky as no phone numbers are advertised. Nightmare! The website just advises us to do checks and expects it to be sorted. If I call the one number stated it is just instructions to do the 'fix it' checks that we have already done via the website!!!!
Please can SKY send an engineer to sort this?
Message posted on 13 May 2025 09:01 PM - last edited: 13 May 2025 09:02 PM
Re: Q box not receiving satellite signal for TNT or GB News
The engineer sent by D & G shoukd have been able to check and adjust the dish. A bit of a cop out there.
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
To call Sky dial 150 (free) from either a Sky Talk landline or a Sky mobile. Alternatively use this link…
https://www.sky.com/help/home
UK customers: Scroll down and click on ‘Need more help’ leading to a number starting 0333.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ to see a dedicated ROI number. (Customer Services in the ROI are not open at weekends).
The forum filters don’t allow the posting of full phone numbers on here.
Calls to Sky will initially be automated which may try to send you here to the forum, offer you online help or offer to send you a text. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
