7
This discussion topic has been answered Discussion topic: Q box has been replaced and still freezing
This message was authored by: Cook5845
My sky Q box has recently been replaced as it was not turning on with having to reboot the box and once it was on it would continuously freeze.
since the box has been replaced we are still having the same issues and they are worse then before.   Since the new box resetting the box does not resolve the issue and we are now unable to watch Sky Q without any issues.
This message was authored by: Scotser Answer
Re: Q box has been replaced and still freezing
Fixed it. For anyone else's benefit all I had to do was reset my Sky Router. I suddenly realised all the problems had started when I changed the router password and maybe split the channels 2.4ghz and 5ghz. So pressed the reset button on the router, 15 seconds and all that, and re-connected the Sky Q box to it and no more freezing, fan getting excited. I reckon it had been struggling to work out IP or DNS address or somthing, causing it to overload and crash.
Hi @Cook5845
This message was authored by: Jonesy2005
Hi, I'm getting the same problem, received my replacement sky Q box last week and it's still freezing and sometimes won't even turn on without powering down first. Any ideas?
This is happening to me too. Replacement box today. Exactly the same thing. Becomes non-responsive, fan goes into overdrive. Loses internet connection and Sky Mini disconnects too. So annoying. I've had it with Sky. It's un-usable!
Do you have an EE router and are you connected over ethernet?
This message was authored by: ozsat
Are the boxes with issues on an open shelf with good ventilation or are they hidden away in cabinets?
SkyQ Silver bundle (V2 2TB with UHD/HDR + two minis) in Sky region #71 (Oxford) using VirginMedia Gig1 Fibre (1.2Gbps/100Mbps).
Surreal. Thanks for the update
