Discussion topic: Q box faults
This message was authored by: Locky
Q box faults
When forwarding a recording screen will stay on picture then jump and to the end and when changing channel the screen will go black and take as Long as 10 seconds to change also we get a lot of buffering when using on demand services
done all the usual power reset software update and checked all the connections with an advisor
Re: Q box faults
@Locky
If you've already tried this troubleshooting with an advisor (presumably on the phone), how was it left? Are they going to swap the box?
Avatar for Locky
Level 0 icon
Re: Q box faults
I had to phone back. just managed to get through again and they are now sending an engineer out at the end of the month apparently very busy
