Discussion topic: Q Box
Message posted on 19 Mar 2025 09:17 AM
Q Box
Last two days our upstairs Q Box not connecting with new Broadband, constantly having to reset Internet provider and password.
Message posted on 19 Mar 2025 10:48 AM
Re: Q Box
Hi @LonJuan
Reboot the mini as above.
Message posted on 19 Mar 2025 10:54 AM
Re: Q Box
We switched broadband provider and there were no issues with the mini Q Box linking up for the first week. Now we are constantly having to reset it and reinstall the network and password. As it keeps defaulting to a Sky network we don't even recognise.
Message posted on 19 Mar 2025 10:59 AM
Re: Q Box
Hi @LonJuan
Your mini box connects to the Sky mesh WiFi generated by Q devices.
When on Sky broadband it can connect to a Sky Router or the main Q box.
On 3rd party broadband it can only connect to the main Q box WiFi or a Sky Q WiFi booster.
Message posted on 19 Mar 2025 11:09 AM
Re: Q Box
It was fine for the first week, no issues. Are you saying that we need to keep running up and down the stairs to get the connect through the main Q Box or is there an easier solution. We changed broadband from Sky Max because it was constantly dropping out often for hours at a time.
Message posted on 19 Mar 2025 11:44 AM
Re: Q Box
Use powerlines
Re: Q Box
As I posted @LonJuan
On 3rd party broadband you need to connect to the main Q box.
The other option is to get a Sky Q WiFi booster to position midway between the Q box and the mini.
