5
This discussion topic has been answered Discussion topic: Projector picture issues with sky Q
This message was authored by: keith.p666
Just purchased a hy300 pro projector and connected it to sky Q . But only.get sound no picture.  I did get picture after resetting to factory on projector, move it outside via hdmi and now there's sound but no picture
Its doing my head in so please help
Avatar for keith.p666
This message was authored by: keith.p666 Answer
Re: Projector picture issues with sky Q
7 meter but ot worked when I plugged it in. took it outside and set up, no picture via hdmi, youtube works fine
How long is the cable?
Firstly, check your projector HDCP capabilities.
Needs to be HDCP1.4 for HD and HDCP2.2 for UHD and related to the Sky Q box model.
Have a read of this previous thread for some background with projectors and Sky Q?
https://helpforum.sky.com/t5/Sky-Q/Projector-picture-issues-with-sky-Q/m-p/4949516/highlight/false#M...
Any further questions, ask here.
Hi @keith.p666   and what resolution?
Same cable? And if you bring it back in it works fine? And vice versa?
Youtube actually playing from the Q as well?
the panel in those things is only 720p so no point feeding it anything higher res than that, which reduces the demands on the cable. I'd try different res outputs.
Answered - Go to Answer
