21
This discussion topic has been answered Discussion topic: Programmes still recording despite removing series link
This message was authored by: Collinsc
Please help!
For ages and ages, we have had the issue where we remove a series link but the programme continues to record.
At my wits end here, any help appreciated!
This message was authored by: ozsat Answer
Re: Programmes still recording despite removing series link
When you do this you will still (usually) get one more recording. Although the link is scheduled it would have already created the next recording.
So you have to cancel the link and also find the next episode and cancel that too.
@Collinsc wrote:
I have selected "Remove series link" from the recordings page.
SkyQ Silver bundle (V2 2TB with UHD/HDR + two minis) in Sky region #71 (Oxford) using VirginMedia Gig1 Fibre (1.2Gbps/100Mbps).
Have you checked all recordings in the scheduled menu?
@Collinsc
Have you removed the series link first before deleting the scheduled recording and also made sure there isn't multiple entries for the same program ?
Avatar for Collinsc
Level 5 icon
Avatar for Collinsc
Level 5 icon
Hi, Yes thats what i do.
yes ive checked that.
thanks
Avatar for Collinsc
Level 5 icon
Any other thoughts? 🙂
Anyone from Sky able to help? Will they respond on here or do i need to contact directly?
@Collinsc
As @caesarome and @PandJ2020 have indicated, go into…
Recordings / Scheduled / find the programme / remove series link / then cancel recording
That's what Sky will advise if you contact them. (Sky won't respond to you on here).
Avatar for Collinsc
Level 5 icon
Thanks for confirming sky wont respond on here.
I have done all of this. Thanks
we'll be able to escalate on here to Sky soon but not at the moment, maybe in a week or two.
Avatar for Collinsc
Level 5 icon
Thanks! appreciated.
Avatar for Collinsc
Level 5 icon
@Chodley This is still happening... how can i escalate this please?
Below screenshots show:
1. The programme series has been deleted
2. The programme has STILL downloaded
3. The programme has "Add deries link" proving that I have not scheduled the series record.
What I neglected to do is get a photo to show that the next episode has not been recorded 'individually',
Shows series is deletedShows series is deletedShows it has still recordedShows it has still recordedShows 'Add series linnk'Shows 'Add series linnk'
P.S No critiquing of the 'Married at First Sight' viewing (It's the Wife's... honest)
Avatar for Collinsc
Level 5 icon
@Chodley - can you help escalate this please?
thanks
thanks
There's no escalation from here.  You will have to call Sky.
Has it downloaded (not recorded) because the previous episode was watched so it teed it up?
