20
This discussion topic has been answered Discussion topic: Mini box not connecting to my sky q box
This message was authored by: Bobbysox11
I have tried numerous times to connect my mini box to the main box but it still won't connect and I am slowly losing patients
This message was authored by: KevNewMedia Answer
Re: Mini box not connecting to my sky q box
Posted by a Sky employee
Hi Everyone
Thank you for coming to the Community to report the problems that you've experienced.
We sincerely apologise for any inconvenience this has caused and can confirm that the original problem has now been resolved.
As many people have found, your main Sky Q box should be powered off at the mains for 30 seconds first, followed by your mini boxes.  If you continue to have problems, you can also find from the Community or our help article here.
I'm going to mark this post as the answer, so that everyone has the most up-to-date information.
Kev
Community Manager
Hi @Bobbysox11
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
Avatar for Bobbysox11
Hi @oldfella
Thank you i will get that a go and come back and let you know how i get on.
Maxine
@oldfella
Thank you back up and running now so did all your step by step advice.
Thank you again
This message was authored by: Clare_A
I have the same issue but it is happening on a daily basis and although switching everything off does eventually fix it, I am getting very fed up having to reset everything several times a day and isn't exactly making me feel I am getting the service I pay for. Any ideas how to fix this permanently?
This message was authored by: Lisac46
I am having the same issue on a regular basis, paying £98 a month for sky I expect not to have these issues!!
This message was authored by: Xxx2
We are having same issue as well so will be ringing sky in AM and wanting answers
This message was authored by: MClem
Re: iMini box not connecting to my sky q box
Issue here between main sky box and sky Q and mine is hardwired by sky!
New main box was supposed to be on way this week (Tuesday spoke to some tech)
They mini just won't connect says. Natalie signal.  Before this error it was stopping signal all the time. Remote engineer has me turn of the 5gz and 2.gz connection which has become turned on  - clearly done remotely as has been off for years!
Will call again Monday, supposed to be getting a call back to see how it's gone. Worse is the answer and for close to £100 a month this is pants at best
This message was authored by: adam+robins
Just read your previous posts. I am also experience this for the last week on all our mini boxes. We have 4 in the house and I've had to pull the blue plug from thw back of all of them several times in the last week. Very annoying. Main q box is connected via ethernet to sky router then others are all WiFi except one in dining room which is connected to ethernet via a tp powerline. We also have some other TP powerlines around the house to connect smart TVs directly to reduce wireless WiFi usage. Do I connect miniboxes to these powerlines to help further or will that stuff up the mesh in house? Powerlines are good TP AX3000 so powerful. Any help appreciated but I'm wondering with the recent posts whether it's a widespread sky issue.
This message was authored by: Karlc
So just been up until 01:29 in the morning banging my head against the wall. Found the issue for me. Turns out that the Sky Q Mini and Sky Q where trying to use the same 192.168.1.13 IP and kept knocking each other off the network. As soon as I set the IP to manual with the following details it spring into life.
SkyQ Mini
IP Adress:192.168.1.14
Mask:255.255.255.0
Gateway:192.168.1.254
My Main SkyQ box was 192.168.1.13z
The above IP's are on my internal LAN. Why would two Sky products try and lease the same DHCP address connecting to a a Sky Router which hosts the DHCP service? Go figure.
This message was authored by: Darla
Me too! I think that's why sky won't let their customer pay by standing order!! The amount of customers that would withhold payment due to a totally abysmal service!! They'd be bankrupt by Christmas
This message was authored by: scorpioclinics
me too - so fed up
This message was authored by: Peter225
I'm having the same problems with mini box connection issues  total waste of money and not getting the service I'm paying for
Yup. We have given up and just reboot practically every time we want to watch the mini box
This message was authored by: TheAce
I have had this problem for 18 months and we even set up a seperate WiFi network
