Discussion topic: Programmes buffering
This message was authored by: Wendywoomaz
None of the programmes Whether live or recorded play properly it's like old school buffering
Re: Programmes buffering
That's annoying.
Sometimes the simplest first step is just to power off the box at the mains for a good 10 minutes (literally pull the power plug).
After that it is worth trying a software update to make sure you are on the latest version: https://www.sky.com/help/articles/updating-sky-box-software-sky-q
Lastly, if that doesn't do the trick, I would get in touch with Sky as your box may have a fault.
