Discussion topic: Programmes buffering
Message posted on 12 Sep 2025 06:30 AM
None of the programmes Whether live or recorded play properly it's like old school buffering
Message posted on 12 Sep 2025 07:45 AM
Re: Programmes buffering
@Wendywoomaz wrote:None of the programmes Whether live or recorded play properly it's like old school buffering
That's annoying.
Sometimes the simplest first step is just to power off the box at the mains for a good 10 minutes (literally pull the power plug).
After that it is worth trying a software update to make sure you are on the latest version: https://www.sky.com/help/articles/updating-sky-box-software-sky-q
Lastly, if that doesn't do the trick, I would get in touch with Sky as your box may have a fault.
sky Q 2 TB | sky Q Mini | sky Mobile | EE Full Works FTTC | LG B6 OLED | SONOS Beam 2
