Discussion topic: SKY Q BOX NOT WORKING
Message posted on 11 Sep 2025 11:33 AM
I recently ordered and received a new sky Q remote but the volume and voice control still dont work which makes me believe it is my SKY Q box
Message posted on 11 Sep 2025 12:06 PM
Re: SKY Q BOX NOT WORKING
May I suggest you try a reset of your remote:
Press & Hold the 7 & 9 until the remote's light (red LED above the SKY logo button) flashes 4 times
Then press 1 & 3 together to go through to re-pair with the box and your TV - make sure it has line of sight of the box as until it is paired it uses Infrared
https://www.sky.com/help/diagnostics/sky-q-remotes/setting-up-remote
Message posted on 11 Sep 2025 12:17 PM
I did this on both old and brand new controller, it reset them and worked for maybe 5 minutes then once again the controller stopping working for volume and voice.
Message posted on 11 Sep 2025 12:32 PM
hmmm - this is very strange as Volume & voice are 2 completely different aspects.
The volume control, once set has no interaction with the SKY Q box - it uses infrared to mimic the codes from the TV's own remote.
Voice control depends on the remote being paired in bluetooth mode with the SKY Q box itself & then the box needs an internet connection
What happens when you try to use voice control - what messages do you get ?
Message posted on 11 Sep 2025 03:07 PM
THey are both non-responsive!! just dont do anything on old controller and the one that arrived yesertday
Message posted on 11 Sep 2025 09:53 PM
Pair it again. Does it work for 5 minutes again?
