Discussion topic: Programmes are not playing. Keeps freezing. Internet is on
Message posted on 10 Jun 2024 06:46 PM
When trying to watch recorded stuff it suddenly the picture suddenly freezes. Can't change channels. Have to restart box. Done this about six times today.
Normal programmes changing is very hit or miss if we can do this.
Sky mini box in bedroom not working.
Message posted on 10 Jun 2024 06:53 PM
Re: Programmes are not playing. Keeps freezing. Internet is on
@Sue+Beckwith You could try resetting the settings in the Q boxes hidden menu.
To enter the hidden menu press the home button and scroll down to settings but do not select settings.
With settings highlighted press 0 0 1 then select
Only Carry out the first Reset being Reset Settings as the others will wipe all recordings.
After the reset you will have to re-pair your remote assuming you are using a bluetooth remote by pressing 1 and 3 together on the remote
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
