Discussion topic: Programme planner
This message was authored by: Ian+and+Lisa
Programme planner
Hi, my programme planner has a lot of blank spaces including today and in the future. I can't record these programmes. Any solutions ?
Re: Programme planner
Hi @Ian+and+Lisa
Have you tried rebooting your Q box?
@Ian+and+Lisa
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if necessary-
~ press the 🏠 button
Avatar for Ian+and+Lisa
Thanks, I'll try this later.
That did the trick, thanks for your help.
