Discussion topic: Problems with tv
This message was authored by: Catherine5012
Problems with tv
I have just had a new router fitted and ever since our tv picture keeps pixelating
Re: Problems with tv
@Catherine5012  Having a new router installed coukld not affect Sky Q live channels as the channels are delivered over satellite not broadband.
Do you actually have Sky Glass/Stream?
Hi @Catherine5012
Assume this is your main Q box?
Have you carried out a Network reset on the Q box?
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
