Discussion topic: My skyQ remote is faulty
This message was authored by: greeniscleaner
My sky Q remote is Faulty
Re: My skyQ remote is faulty
@greeniscleaner
You haven't said how it's faulty or what you've tried already … If your Sky Q remote is definitely broken/faulty, if you follow this link it should allow you to do some troubleshooting and then it’ll send you to a form to request a replacement (apparently this is not available to customers in the ROI).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
It might be quicker to purchase a new one from a retailer / main supermarket. If you do that as well you’ll always have a spare.
Hi @greeniscleaner
Try completly resetting your Bluetooth remote.
