Discussion topic: Problems with sync sound
Message posted on 08 Nov 2025 03:52 PM
Optical cable from sky box where should it be connected to ,sound bar or tv, asim having trouble synch up the sound many thanks
Message posted on 11 Nov 2025 08:33 AM
Re: Problems with sync sound
hi @Phil257
the optical connection on a TV is only output so connecting an optical cable from the KSY box should not go to the TV & should be connected to the Sound Bar.
Connecting SKY Q to the Sound bar usually gives few problems with lip synch but it depends on the TV
If your TV has apps that you use & your TV can pass through the bitstream signal from SKY Q you may be better connecting the optical out from the TV to your Sound bar, as then you can use the sound bar for both the TV Apps (& DTT if you have HD channels) but this can be more risky from a sound sync perspective from SKY Q
