Discussion topic: New sky q mini
Message posted on 07 Nov 2025 07:14 PM
New sky q mini
Trying to set up my new sky q mini. Seems to be connected but tv is showing Progamme Unavailable?
Message posted on 07 Nov 2025 07:49 PM
Re: New sky q mini
Hi @Dave30041
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
Message posted on 07 Nov 2025 09:30 PM
Re: New sky q mini
Many thanks for the detailed instructions. All looked good and got the green led light on the front of the mini, but still getting the same message saying check my subscription entitles me to view this channel, ie BBC!. I'll get onto Sky. Thanks again
Message posted on 11 Nov 2025 06:47 AM
Re: New sky q mini
Seems lit needed an overnight update to sort it. Cheers 😊
