Discussion topic: Problems with multi room box
This message was authored by: Sarahlou10
Only had sky for just over a week but ever single day without fail we have had problems with the connection on the multi room box. Can anyone help please.
Re: Problems with multi room box
@Sarahlou10 Have you tried rebooting your main Q box ie
then
rebooting your mini boxes
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Hi @Sarahlou10   If you have only had it a week, I would get Sky to come back and sort it out.
Avatar for Sarahlou10
Thankyou.
Thankyou yes we did try that. We think it happens when we turn the tv upstairs off with its own remote, so we haven't done that for a couple of days hopefully this is the reason.
