Discussion topic: Faulty
This message was authored by: Micky45678
Faulty
Can't pause , rewind or record , screen goes blue on some channels
Re: Faulty
@Micky45678
Its always worth starting with a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
Avatar for Micky45678
Re: Faulty
Thanks Daniel, I failed to mention that I've done a reboot several times to no avail, and now this morning Sky Go is playing up too with error code PFE 9001-IH, cheers for the prompt reply but I'm not sure what to do next
Re: Faulty
@Micky45678
See this thread re the Sky Go issue
https://helpforum.sky.com/t5/Sky-Go/Not-all-channels-available-on-Sky-Go/td-p/5317874
