Discussion topic: Problems with mini box
Message posted on 09 Aug 2024 07:09 PM
Cannot get my sky q mini box to move off accessibility page
The remote is working
Message posted on 09 Aug 2024 07:19 PM - last edited: 09 Aug 2024 07:21 PM
Re: Problems with mini box
Hi @B_RICHARDS5
First try rebooting your mini box?
To reboot press Standby on your mininremote (if the box responds to the remote), and then switch off and unplug at the mains.
Wait at least 30 secs and then Plug back in and switch your mini box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your mini remote or if this is not working press the standby button on the front of the mini (Amber led)
Then with the mini box on with green led try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
Message posted on 09 Aug 2024 07:21 PM
hi @B_RICHARDS5
Try the following
On your SKY remote Press & hold 4 & 6 together until the red led above the SKY logo button flashes 4 times
This sets it to IR mode
Now try to dismiss the message - the remote needs direct line of sight of the box
If this does not work try a full remote reset by pressing & holding 7 & 9 as above
Once (if) you mange to dismiss themessage Press & hold 1 & 3 together to re-pair the remote with the box & TV
