Discussion topic: Sky Q opens as normal but cannot view live or saved programmes
This message was authored by: KC64
Opens as normal but when trying to view live TV it says there is a technical problem and screen stays black. Saved programmes show as being there and you can click to view them but they don't open. It lets you click on download and says it is complete but you cannot open them.  Broadband is working fine.
Re: Sky Q opens as normal but cannot view live or saved programmes
@KC64
Have you tried unplugging the Sky Q box from the wall, leaving it for 5 minutes before plugging back in to reboot?
It's a good first step to clear many problems.
This message was authored by: Tracey139
The hub is not connecting to the sky tv, when pressing wps button still nothing happens, this has been like this all week, im tired of not having wifi, we dont have it for our ring door bell, which is important, and also I need it for work, and I cant get nothing, why does this keep happening, we came back as we were promised it would be better this time, nothing has changed, something has to be done.
I think we need to move this to it's own thread in the broadband section @Tracey139.
Hi @Tracey139
