Discussion topic: Problems with mini box
This message was authored by Mike270 This message was authored by: Mike270
We have 3 mini boxes. There is a problem with one of the boxes. The main menu comes up and can change channels but no picture It just stay black. It keeps coming up with the saying there is a fault with this channel please try later. We have turned everything off and nothing. We have gone to the settings and it is saying that everything is working. Even when we have reset the settings.
Re: Problems with mini box
Hi @Mike270
First swap the problem mini with one of the others to see if it is the location causing the issue.
If it doesn't work then try rebooting the main Q box and then when this is completely back up and running reboot the minis.
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
Mike270
Hi oldfella.
Thankyou for your psychy on fixing my problem. It worked, all up and running now ,had a bit of running around but by the end of it, it's a goodun. Turns out it was the main Qbox that was out of line but by resetting it the mini box linked in and fired up. Brilliant. Thanks.
