Discussion topic: Problems with MR102 error
Last night at 21:00 - we suddenly had an MR102 error on our WiFi connected remote Q box
We don't use Sky internet and have a good WiFi signal in the bedroom (65Mbps)
This took almost 30 minutes  to resolve
Why should it suddenly do this ?
Never had any problems with HD or previous boxes in 21 years
let me just say that my wife almost threw the remote box out of the window last night
Moderator note: subject of thread updated to better reflect the conversation
This message was authored by: Adam+sky+82
Re: Problems with MR102 error
This sounds like a network problem. Have you tried disconnecting both main Q box and mini from the wifi and then reconnecting them? The mini box gets its feed from the main box so the problem might be with your main box
Hi @Anonymous
Your Network WIFi signal in the bedroom is irrelevant as your Q box cannot connect to this.
Mini boxes on WiFi will only connect to the WiFi mesh generated by the Q box when using 3rd Party Broadband.
If it happens again  try a Network Reset on the mini.
