Discussion topic: Problems keeping internet connection after disconnecting sky Q mini
This message was authored by: LizzyA
I have recently stopped my sky multi room (not used enough and too expensive!) so have unplugged the sky mini for return. Since then my main sky q box keeps loosing  internet connection.  I keep having to reset and press the wps button on the router but it keeps dropping out.   Any ideas?
Re: Problems keeping internet connection after disconnecting sky Q mini
Assume you are on Sky Broadband @LizzyA ?
Avatar for LizzyA
Hello! Yes we have sky ultra fast broadband
Hi @LizzyA
Do you have a Sky Max router ?
Avatar for LizzyA
It's the white one which stands up!  Is that the sky max?!
I also have a sky plug in WiFi booster
Yes I think that is the Sky max router @LizzyA
These would seem to work differently to previous Sky hubs.
Instead If using WPS to connect your Q box to the router try using SSID and password.
