Discussion topic: Broadband not working properly and not connecting to sky Q
Message posted on 29 Dec 2024 08:34 PM
Message posted on 29 Dec 2024 08:53 PM
Re: Broadband not working properly and not connecting to sky Q
@Rich+cooper wrote:
Our broadband is not working properly and we also can't connect it to sky Q at the moment. I tried what is suggested with the sky Q issue but it wouldn't let me order a new sky Q box and then wouldn't connect to a sky chat and kept going round in circles
Hi @Rich+cooper
Have you completed the following?
