Discussion topic: My sky Q is not connecting with my mini box
This message was authored by: Remiabiola
My mini sky box is not connecting to my sky Q
This message was authored by: Pat34
Re: My sky Q is not connecting with my mini box
My 2 mini boxes are not working.
Also there are difficulties with connecting the main box with my home wifi
Both my mini boxes are not working
My Main Sky Q box has an intermittant fault with my home wifi
Hi @Remiabiola
Reboot the mini as above.
