2
This discussion topic has been answered Discussion topic: Problem with mini box
This message was authored by: Fredericka53
Yesterday my TV on the mini box said "Technical Fault with this channel". I rebooted the mini box and the main Sky Q box. I checked that it was connected to wifi but the problem persisted and I could not access normal TV channels but was able to watch Apps. Today the message has changed to "no satellite signal" though again I can access Apps. Any ideas?
Re: Problem with mini box
Hi @Fredericka53
Reboot the mini as above.
Hi @Fredericka53
Avatar for Fredericka53
Thank you. I will try all that.
Answered - Go to Answer
